Hi this 3 yr old Wmb61431b wont lock the door I’ve swapped out the interlock no joy , main board fault I take it , no sign of any burning on it anyone come across this thanks
replaced board today , turned on m/c and heard a loud pop from the board ,,, can afaulty door lock blow the board , it still lights up and the door will lock but nothing else happens
Correct, if the door locks then the locking triac is likely to be ok.
Sounds like a short somewhere else in the machine which would only blow when the lock thermal switch closes.
Any damage visible on the new board?
