Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Beko washing machine drain problem
- This topic has 4 replies, 3 voices, and was last updated 11 years, 8 months ago by
tinfish.
July 23, 2014 at 9:36 pm #81583
tinfish
ParticipantHello,
I’ve been having an ongoing fight with an integrated Beko. The customer was complaining that it wasn’t draining, the there was water leaking out of it on the spin.
I had a look and the drain pump was knackered, so I changed it, had a cursory check for blockages, tested it and it seemed fine. A week or so later she was on the phone saying it had done it again on the 3rd load of washing she’d done that day (back from a holiday).
I’ve since had everything from the sump to the U bend off and there are no blockages, I checked the board and there are no signs of overheating on it.
I have only had it almost repeat the problem once – the pump was going, but it was very slow to drain. I’ve had it apart since then and she says it’s happening again…Has anyone else had a similar problem, or is this more likely to be a problem with the drains?
As always any help would be greatly appreciated.
Grant
July 23, 2014 at 10:14 pm #417089Martin
ParticipantRe: Beko washing machine drain problem
Could it possibly be a sticking sump ball valve? Gloopy liquid detergent can make them stick and water can leak from dispenser….????
July 23, 2014 at 10:25 pm #417090tinfish
I’ve had the ball out and is seemed fine – it’s worth a try, I’ll give it a good wash, or maybe just misplace it.
I’m sure the water is being thrown up the inlet pipe and out the dispenser. There is a bit of rust at the bottom edge of the dispenser and a clear run mark down the inside of the front panel.
July 23, 2014 at 10:46 pm #417091jag-12
Button or coin in the drain hose ?
Had a few over the years. Keep bamboo stick in the van to prove them clear !
Does it go into a stand pipe or direct into the sink plumbing?July 25, 2014 at 10:29 pm #417092tinfish
I’ve had the drain hose off and shoved something down it – I was expecting a 5p, but nothing. It plumbs in under the sink.
She’s back from her current holiday on Saturday, so I’ll probably spend an exciting monday morning hauling it out again. -
