Going into test mode of my Beko WMB61631W washing machine it displays E06. I assume this is an error code. Can someone advise what this code is. On the next press of the start pause button 052 is displayed what is this too please. Subsequent presses of the start pause key goes through the various tests which seem to be OK…Thanking you
Just to add…getting the machine to work in any mode ie wash, rinse or spin/drain results in the motor spinning up for a couple of seconds trying again for 2 more goes then going straight to END. BEKO gave me limited help but suggested the motor relay (is this also called a ptc relay) is at fault. Can anyone shed any light on this….Thank you
