Beko washing machine only rotates left Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Beko washing machine only rotates left This topic has 5 replies, 2 voices, and was last updated 6 years, 9 months ago by Keng3155. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts July 3, 2019 at 8:22 pm #96102 Keng3155Participant Hi All I have a Beko washing machine WMB81241 LB it stopped working properly I ran a test cycle and it didn’t turn the drum to the right everything else seems OK. I replaced the motor brushes but this has not sorted the problem. Can anyone help July 3, 2019 at 9:16 pm #462357 electrofixModerator the motor is reversed by relays on the control board check the board for bad solder joints on the relays Dave July 4, 2019 at 6:22 am #462358 Keng3155Participant Cheers Dave, will check it out at the week end Do u know the price of a control board or even the part number Ken July 4, 2019 at 8:39 am #462359 electrofixModerator part number should be 2427807380 but you will struggle to get it as non stock beko parts can be a pain Dave July 4, 2019 at 8:45 am #462360 Keng3155Participant Cheers Dave Thank you6 July 14, 2019 at 8:44 pm #462361 Keng3155Participant Hi Dave managed to get a new control board and fitted it and it has fixed the problem so Thank you for your help.. cheers Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
