Re: BEKO Washing Machine WM6355W 1500rpm Drum Bang and knock
Just like car shocks, push down on drum and they should’nt bounce. The speed of the motor is controlled by the tachometer generator on the end of the motor. It’s like a dynamo, generates a small electrical current that is measured by the control module. If the motor suddenly breaks into a fast rotation then the problem is associated with that tachometer circuit.
From your description I would think the problem is not the shocks though they are cheap to replace anyway,
