As soon as machine is switched on it goes directly into drain mode,with door lock symbol & END flashing.
Seen a couple of posts with same problem one has a pm reply, but no answer to be seen on forum any help much appriciated
Darren
Bekos always seem difficult to cancel the programmes, especially if there is an error state, ie brushes worn or water in the drum. Always worth checking the brushes on these! Good luck!
Thanks Jason1970 went through the basics brushes etc on first call but everything seemed OK presumed it was a board fault hence asking on here. Thanks for reply
I sometimes find if you can enter the diagnostic cycle this will reset the machine back to the start program option.
If my memory serves me right.
Switch off-Select 90 degrees program-switch on while pressing start button and hold for a few seconds-you should then be in diagnostics-press again to start diagnostics.
Hope this helps.Good luck.
