Beko Washing Machine WR860441W will not power on
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko Washing Machine WR860441W will not power on
  • #99144
    WannaFixWasher
    As is typical with these things, 13 months from the delivery date, the washing machine doesn’t work, no warning, just no power and no reaction to any controls.
    I’ve checked the plug & fuse, checked the socket, all OK.
    I’ve taken the lid off & checked that there is power arriving to the mains capacitor – this is fine & there are no burn marks.
    the only other thing I have done, is check the PCB to see if anything stands out
    1. There is (in a few different places) some white marks on some of the soldered pins, not sure why this is the case, or whether it is causing an issue & should be cleaned off
    2. there are 3 capacitors, 2 of them – the large black one & C33 – one of the smaller blue ones have continuity, the other blue one (C17) does not have any continuity when checked with a multimeter. I’m therefore assuming that the 2 with continuity are busted.
    So I wanted to try to fix it before calling an technician, as that is guarranteed to be over a £100 in Essex, and its harsh for a washing machine that’s 13months old.
    Does any one have a clue as to what to do? any suggestions. If not, I will have to bow to the pressure from the better half to sink more money into it. Alternatively, I could buy a new PCB…
    Images are of front & back of the PCB showing the 3 capacitors.
    https://ibb.co/CmKkvDd
    https://ibb.co/WfJ3p46
    Thanks!
    #475175
    tubafan
