BEKO washing machine WTB941R2W – stops on rinse
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BEKO washing machine WTB941R2W – stops on rinse
  • #101776
    asp11
    This machine works fine on heat/wash then it empties the dirty water, fills a little, spins a little (with red wash light on)
    Then it fills for a few seconds, the red light changes to rinse….. and then it stops and is silent….
    If you stop it, turn to spin/empty it’ll work fine – there’s no buzzing from the valve when it stops after changing to the rinse light….. just silence!
    I’m thinking control board but thought I’d ask on here first
    Thanks for any help?
    Pnc = 7145641800
    #486007
    matrixresonator
    Ive had this a couple of times, been a dead rinse valve both times.
    #486008
    asp11
    matrixresonator wrote:Ive had this a couple of times, been a dead rinse valve both times.
    That does sound logical but why can I hear a small squirt of water intake before it goes silent?
    #486009
    matrixresonator
    What I did was check for voltage at the valves, also on fill swap the connectors over and the rinse valve should fire up to show if its working or not.
    #486010
    have sent you the service manual to hotmail acct
    asp11
    electrofix wrote:have sent you the service manual to hotmail acct
    THANKS Dave
    #486012
    asp11
    matrixresonator wrote:What I did was check for voltage at the valves, also on fill swap the connectors over and the rinse valve should fire up to show if its working or not.
    Just to confirm = the valve fixed the problem, so THANKS to you both for your help
    #486013
    matrixresonator
    Glad to hear you’re sorted
