Beko WD beeping and flashing prewash light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WD beeping and flashing prewash light
  • #102305
    pmb
    Hi I have a Beko WDIX8543100 which I had trouble turning on, once I did I started a quick wash and it worked but beeping regularly while flashing the prewash light. I couldn’t turn the machine off using the on/off button so had to let it run.
    It did seemed to do everything ok.
    Can anyone help me out on this one?
    Thanks, Darren
    #488275
    well if there was an error i would expect an error code
    this is more like a programmer problem
    first thing i would do is disconnect the heaters as we all know odd earth faults can cause all sorts of odd faults
    after that i would open the board and look to see if any of the caps are bulging
    pmb
    Thanks Dave great advice, I’ll let you know how I get on
    #488277
    hebegebe
    Just a thought. I’m not familiar with the particular model, but on a lot of Beko machines, you can’t cancel the programme, unless the selector is set to the programme that is running. If it has been moved, then it’s a case of select each programme, and try to cancel until you find the one which works. It should however restart normally, once the programme has completed on its own. Graham
