Beko wdix8543100 no motor action
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko wdix8543100 no motor action
  • #101114
    allan
    Hi, been out to Beko wdix8543100 with no motor action, no fault codes, fills empties, drum has a lot of resistance unless motor unplugged, anything I can try to establish if motor or motor board? Thanks Allan
    #483414
    have emailed the trouble shoot guide
    stratfordgirl
    I have never come across a Beko washing machine with a failed inverter motor (except some early motors which had on-board electronics), but many times a failed inverter board, particularly on Beko.
    #483416
    Hollytree_Technical
    With the power off unplug the motor then test the resistance between the 3 wires coming to the motor from the inverter (not the motor), if you get a low resistance or short then it is a faulty inverter board.
    It is also a rarity for a inverter driven motor to electrically fail as they don’t have any moving electrical components but it is common for the circuit baords that drive them to fail – this applies to all makes.
    Jem
    #483417
    rub
    Sorry I’m late to this but it will be the motor pcb, it always is for this fault
    #483418
    matrixresonator
    electrofix wrote:have emailed the trouble shoot guide
    Any chance you could fire this over to me too please, got one to go to and be nice to be able to narrow it down to either board or motor.
    #483419
    sorted
    matrixresonator
    Thank you.
