Beko WDIY854310 dryer cuts out
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WDIY854310 dryer cuts out
  • #100708
    Gazpacholulu
    I have a Beko washer dryer where the thermal cut out trips everytime the dryer is used (very rarely). Reset it, unit dries the clothes then won’t dry the next time. Have ordered replacement cut out just in case but I doubt that is the cause merely a symptom. Any help gratefully received.
    #481842
    more likely the fan sticks and the element overheats
    Gazpacholulu
    Thanks, is that the fan on top of the assembly or the internal one?
    #481844
    Gazpacholulu
    Fan starts up after about 5 mins (external fan)
    #481845
    Gazpacholulu
    Tripped after 10 mins, fan still running
    #481846
    well the only reason for a trip is an air flow problem or faulty stat. since the unit works second time then its unlikely to be a stat problem.
    time to have a look at airflow
    Gazpacholulu
    There is some horrible white powder coming out where the air enters the drum. Strip the fan unit down?
    thanks Dave
    #481848
    white powder is aluminium oxide. yes strip and look for anything that stops air flow
    Gazpacholulu
    I tried to split it open, undid the 6 or so T20 torx but it didn’t want to come apart. Saw B&Q are selling it for £130 delivered so didn’t continue for now. May look again in the morning. Thanks again.
    #481850
    its a clearance price at B & Q so you might find stock difficult
    if you can get one jump at it as it should have 2 year guarentee
    Gazpacholulu
    Got my big pants on today and split the dryer assembly: it was like rats had been nesting and died in there. The fan assembly was solid as if it had sucked in a filter or something. A lot of elbow grease and wd40 its much cleaner. Now I’ve set it to run for 150 mins, with the heating element detached, to hopefully blow out any more rubbish and allow the solvent time to evaporate before adding any heat. Fingers crossed.
