Beko WDK742421W
  • #101726
    Hollytree_Technical
    Hi All
    Does anyone have the service information for this machine please?
    I have not seen it yet but have been told that it has E00 and E07 error codes.
    Thank you
    Jem
    #485800
    clockworkone
    E07 is pressure switch or related wiring. Can’t see anything for E00.
    #485801
    have sent fault list
    Hi Jem
    did you visit this one ?
    just had someone ring and say it has E00 code
    any results ?
    Hollytree_Technical
    Hi Dave
    Sorry but I don’t remember if we ever got to the bottom of it, I think it got put down to a possible damp/insulation fault.
    Jem
    #485804
    well on mine it turned out to be a broken wire to the pressure switch due to the module container snapping the bracket and bouncing up and down when the drum moved
    new module, repair snapped wire and fault code dissappeared
    found it by accident as wire must have been broken inside insulation
