Beko Wdr7543121 door lock
  • #96133
    allan
    Hi can anyone -lease tell me what the extra door switch with the white plunger is on the Beko wdr7543121 is for, does it stop the display from working until the door is closed? Cheers Allan
    #462446
    don’t know but switch was removed on later models so whatever it does Beko decided it was not necessary
    cant see it switching off the display
    have you got a no power problem on the board ?
    allan
    Yes nothing, dead, have power to board.
    #462448
    cant see it being the switch and anyway you could check the switch for continuity
    whats the power supply on the board transformer or switch mode chip
    if its switch mode look for the fusible resistor and see if its blown. normally 40 to 80 ohms or so
    allan
    Thanks Dave will do
