PLEASE HELP…………..My BEKO Washer Dryer WDR7543121B will not spin.
it is 18 months old and has been working fine. No unpleasant noises.
It fills and will pump out. The filter is clear. the load is not un-balanced (as have tried running with different loads and empty). The motor is a brushless pro smart. The motor turns freely by hand, the belt is a good tension and not worn.
I have moved from the UK to NZ and as it is not an NZ model no one here can help and Beko have been pretty useless. If anyone knows the likely problem i am happy to repair but need to order parts from the UK……….So i want to try an get it right first time.
Many thanks in advance.
Usually suspect is the motor control module. In a black holder the thing with the largeish silver coloured heat sinks. This part fails. Any capacitors that look swelled or with domed tops may well give the game away as to where the problem is. The Bosch version on the same brushless motor theme also fails the same or similar way too.
