Andrew McHugh wrote:I beep / It’s quite likely we’ll replace our dryer in the near-ish future so can live with the workaround in the meantime but good to know if anyone cracked it. thanks!
assume you mean Washer /Dryer not just dryer
looked up the fault code and all it says is change lock , if that fails check wiring, if that fails change board
also dont forget you can probably get that fault code if you leave the door open an d then if the machine has no other fault the code will stay in memory so it will seem like its a current fault
as a long shot i would disconnect the dryer heater and wash heater elements and see if it makes any difference
