Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Beko WDR7543121W Replaced PCB now double beep and E23 error
- This topic has 19 replies, 6 voices, and was last updated 6 years, 1 month ago by
ali_g12.
February 17, 2020 at 1:18 pm #97206
ali_g12
ParticipantMy Beko WDR had the no display symptoms but was beeping so I replaced the main (power) PCB as recommended in other threads on the internet. This restored the LCD display but any attempt to start a program were met with a double beep sound almost as if the childlock was on. Indeed, the machine does the same with the childlock turned on so I’m sure it’s not this.
In diagnostic mode I get E23 on most of the tests and they won’t start but strangely when I come out of diagnostic I am able to start a program and the door locks and machine behaves as usual. If I then drain the machine out and allow the door lock to disengage I have the same symptoms when I go to start another wash and I have to go into diagnostic mode and come out again.
It seems a door lock related problem but I have replaced the door lock and it functions as it should do anyway when the machine agrees to work!
There’s no information on these anywhere so I’ll probably need the advice of a Beko engineer or appliance genius. Any thoughts?
February 17, 2020 at 4:34 pm #466541kaibart
ModeratorError 23 is a door switch (white secondary) faulty if this helps
February 17, 2020 at 6:52 pm #466542ali_g12
Participantkaibart wrote:Error 23 is a door switch (white secondary) faulty if this helps
Thanks for the input. I had a feeling it was door lock related. It’s strange that the door will lock after having been in diagnostic mode. I know the lock itself is OK as I’ve replaced it. Is it a case of clearing the fault code from memory after replacing the PCB? Or do you think it is a wiring harness issue?
February 17, 2020 at 7:36 pm #466543kaibart
ModeratorI would check the wiring on the dryer side if that’s ok I would check the wash heater
February 20, 2020 at 12:50 pm #466544ali_g12
Participantkaibart wrote:I would check the wiring on the dryer side if that’s ok I would check the wash heater
Checked wiring from dryer element, heater element and door lock all the way back tot he connectors on the board. They’re all OK. Ran machine on dry – that’s working fine. Both elements have continuity and not leaking to earth.
As before, I can run a cycle outside test mode only if I have come out of test mode with the door lock still engaged. If I just try and run the cycle without having been in test mode (and engaging the door lock with a test) then I get the double beep.
Anymore ideas? Could it be a software issue? Anyone got a service manual?
June 17, 2020 at 1:45 pm #466545Richard Wilson
ParticipantHiya; Did you find a resolution to this problem? I replaced a PCB on the same model and now have exactly the same problem. Washer/Dryer will run as normal but only after I have run and cleared a diagnostic test! Serves me right for buying a BEKO!
June 17, 2020 at 4:42 pm #466546ali_g12
ParticipantI think it was a software issue. The manufacturer’s service agents came out under customer’s insurance and replaced the PCB (again) but in reality probably just programmed it. Let me know if you get to the bottom of it.
June 17, 2020 at 6:19 pm #466547electrofix
Moderatorlet me have the product code of the machine and the part number you replaced
that way i can check to see if you have the correct part
it may look the same but if it has different software it wont work
September 14, 2020 at 8:20 pm #466548Stefano Di Gregorio
ParticipantAny updates on this issue? Please help me
September 14, 2020 at 9:55 pm #466549electrofix
Moderatoryou may have a similar problem but the above person changed a board
since he never replied i dod not find out if he fitted correct partDave
September 15, 2020 at 12:26 pm #466550Stefano Di Gregorio
ParticipantHi Dave, i did the same things the lady did in the post. I changed the PCB board as suddenly the machine stopped working completely. After changing it the machine came back alive but i couldn’t wash because the door doesn’t lock. I entered in test mode and appears E23 error, which i suppose is exactly the door lock code error. I checkked the wiring and i changed the lock. Nothing it doesn’t work. The only way to let the machine starting the cycle and wash my laundry is to enter in test mode that manages to lock the door, than turn it of and on again. In this way the door is still locked and I can start washing.
It is strange what it does because the lock works in test mode and the machine works fine with the trick i am using. I think it is just the case to reset the machin/board.
do you have any ideas?Thanks
September 15, 2020 at 4:36 pm #466551electrofix
Moderatoryes
give me the commercial code of the machine( begins 7 normally) , model and serial
then tell me what board part no you have fittedwill prob be a change of board and you have got the wrong one which has different software
have had this beforeDave
September 15, 2020 at 6:53 pm #466552Stefano Di Gregorio
ParticipantHi David
thanks for your time, here you have the codes:Machine:
Commercial Code 7161541500
Model Beko Wdr7543121w
S/N 18-402867-03New PCB
S/N 3319003813
Rev: g09-b03-t01-d01
Y/N Terma_FTC_07hopefully it can help for clarifying the issue. Is there a way to reconfigure the board?
Thanks a lot
September 15, 2020 at 7:21 pm #466553electrofix
Moderatoryou did not give me the board part no you have bought but part no i have is 2437301081
check that against what you bought
September 15, 2020 at 9:12 pm #466554Stefano Di Gregorio
ParticipantThere are two note on the pcb, one says what i wrote before. And the other shows this: 2437301080
There is a 0 instead a 1 at the end.!!?? -
