Beko WDX8543130W — goes dead soon after starting
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WDX8543130W — goes dead soon after starting
  • #100190
    asp11
    I’ve read through the 7 pages of a previous problem on here, like this but this is different……..
    This machine will start on any setting, fills up then before it turns or heats the display shuts down and it just sits there…… if you turn it off then & back on again it lights up straight away and you can start it up again…. then it does the same thing??
    The cx complaint was actually “with 6mins left it made a few awful banging noises and stopped” …… I haven’t got that far yet…..
    I’ve tested the heater and motor, both seem good, so I’m thinking its the main board as it’s doing something really strange?
    Any ideas please?
    #479668
    when you say dead is that all lights off / no power at all
    asp11
    electrofix wrote:when you say dead is that all lights off / no power at all
    Yes about 5mins into any program the machine just shuts off, no lights, no sound…. must still have power going to it though because if you press the power button it comes back to life….. very strange?
    #479670
    well it does sound like a board power supply issue. it sounds like it try to heat and dies
    does it work on a rinse programme when there is no heat
    have you checked heater for earth problems
    if all fails you could try changing the board power supply chip
    asp11
    Thanks….. I’ll check it again
