beko wi1573
  • #91170
    mikehha
    good evening all
    We have here a beko wi1573 with no motor action also if you pause and cancel the program the door interlock wont release and the pump cuts in and out.until you turn it off at the mains.I know there has been a problem with the dc modules but would this affect the lock and program
    #447320
    Re: beko wi1573
    not sure if you have tech access so have pm’ed you some info
    dave
    #447321
    mikehha
    Re: beko wi1573
    many thanks for the info dave will store it away for a rainy day.The information you sent seems to be for a 3phase motor mine is brushed. but it gave me the jist of the fault codes and where to look so again many thanks
    mike
    #447322
    Re: beko wi1573
    no probs m8 anytime
    yours must be on the change over to brushless so will prob be machines out there with same model with brushless motor.
    Seamy
    Re: beko wi1573
    DC modules were prone to popping out the track of p.c.b if too much current was pulled by the motor. Have found excess brush dust sometimes shorted out to motor frame causing same problem.
    Check loom to pump for shorting against front frame , got this problem on a few of the basic Beko’s.
