My washing machine won’t progress past the fill stage. It fills and the drum turns fine but that’s as far as it goes. I’ve cleared the filter . If I put it manually on drain and spin it will do that fine. Advice very welcome as it’s only 2 years old
the machine is progressing pass the fill stage as long as the water stops. you then say the motor turns, one way or both ?
does it heat?
how long did you leave it before you decide its not going anywhere?
have you tried just a rinse cycle and a spin cycle to see if it completes those programmes ?
