beko wm wma765s
  • #42800
    funkyboogy
    main wash light flashing, nothing else happens
    any ideas, looked through fault codes but the codes for beko dont seem to corrospond to this app?
    ally
    #274963
    funkyboogy
    Re: beko wm wma765s
    found this googling… dont know if it will help with the fault i have,
    but may be of use
    Beko wma reset procedure
    Turn power button off (not at wall)
    Select 90 degree wash
    Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down – Start light will flash.
    Leave power on.
    Select any Spin position.
    Press Start and Cancel button at same time again for 3 seconds – other buttons may start to flash – if they do, press Start and Cancel button together again for 3 seconds.
    Machine should be re-set ready for use.
    ally
    #274964
    Re: beko wm wma765s
    Google, pfft. :rolls:
    If you had used the forum search facility and entered “Beko AND flashing” in that exact format you would have got pages of info, several of which contain that information. 8)
    funkyboogy
    Re: beko wm wma765s
    cheers, i had looked through fault codes but didnt hink to search
    dohhhhhhhhhhh
    ally
    #274966
    Alanj
    Re: beko wm wma765s
    Hi Ally,
    have you checked the motor brushes? 😀
    Alan
    #274967
    wilf
    Re: beko wm wma765s
    sorry to say I find the search pretty useless as it seems to lead to pages and pages to trawl through often without any usefull result.
    I dont mean this as a complaint only as a possible usefull comment that might be a spur to improve what I now regard as a top site.
    wilf
    #274968
    Re: beko wm wma765s
    The secret is to narrow your search down by using AND, it works really well if you do.
    Make sure the AND is in upper case.
    If you enter ‘Beko flashing’ you will get every single thread that includes the words Beko and everyone that includes flashing, in other words hundreds of posts on Indesit machines.
    If you enter Beko AND flashing you will narrow your search down to a much smaller number of more relevant threads. 😉
    From the search page.
    Search for Keywords:
    You can use AND to define words which must be in the results, OR to define words which may be in the result and NOT to define words which should not be in the result. Use * as a wildcard for partial matches
    funkyboogy
    Re: beko wm wma765s
    havent checked brushs , but will do..
    cheers ally
    #274970
    knobs
    Re: beko wm wma765s
    Been to a few of these,seems the machine gets a bit upset if the pump is bloked or jammed.
    The pump runs for a second or 2 at the start of the prog ..if it doesnt the start light flashes
