hi guys went to repair a beko eco care washing machine model wm 1210s problum not spinning. checked filter pump motor brushes pressure switch clicking when blew into it. not spinning on any of the spin programs A B C just keeps pumping out the drum would turn slightly as if it was going to spin would this be a board fault or can the machine be reset. thanks fasetester.
Board fault. It’s behind the front panel. They fail for no reason, often explosively. The part number is 2802090200. I have no idea how much your wholesaler will charge you for it.
