Beko WM1412 drum not turning/spinning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WM1412 drum not turning/spinning
  • #21716
    markmark
    My Beko washing machine is filling up with water and emptying fine and the timer is clicking/making all the right noises, but the drum fails to turn at all during a wash cycle or spin on a spin cycle.
    I read a post lower down with a similar problem.
    Would a check on the brushes be the first place to look here?
    Thanks.Mark
    #192267
    Dave_Conway
    Re: Beko WM1412 drum not turning/spinning
    markmark wrote:Would a check on the brushes be the first place to look here?
    Yep, that’s a good starting point 🙂
    Pull the plug first please :zap:
    #192268
    markmark
    Took the brushes out and they were indeed worn down, not as much as I would have thought but still only 6 or 7mm left.
    Gave a quick clean and put them back on and the WM is working again now, though I will probably have to buy a new set fairly soon.
    #192269
    If it has stopped once, the brushes are on their limit. Stop using it and get the new brushes now, before you cook the armature!
    An email to spares@ukwhitegoods.co.uk should get things moving for you. Dave will need to know whether the motor fitted is made by FHP or Arcelik – the name is usually on the label on the motor.
