beko wm1412s won’t spin/drain.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum beko wm1412s won’t spin/drain.
  • #50247
    glennchambers
    can someone please help me, my washing machine has suddenly decided that it doesn’t want to spin/drain anymore and the door won’t open because of this. what i need to know is where to find both of these. on previous models i’ve had the filter has been clearly visable at the front of the machine, but i can’t seem to see anything on this one. hopefully someone will be able to help me. thankyou.
    #304106
    Re: beko wm1412s won’t spin/drain.
    Pump filter will be behind the kickboard across the bottom of the machine.
    glennchambers
    ok penguin thanks for that i found it. problem 2 i have taken the filter out and found some coins, i have removed them and done another wash. this time it lets me open the door, but unfortunately my clothes are still sopping wet. any ideas?
    #304108
    helo_75
    belt off?
    brushes?
    #304109
    glennchambers
    thanks for previous help guys. what i have done now is taken the back off the machine, the belt was in place. also i tried draining the machine and could hear the pump working. i have taken the brushes off and 1 of them was quite badly melted. i am presuming that this means they need changing? the other thing i noticed was that the part of the motor that the brushes touch onto looks as though it has worn on a part of it. does this mean that the motor will have to be changed aswell? if so would it be better to get a new machine or replace the parts? thanks.glenn.
