Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › beko wm1512 motor run-on
- This topic has 10 replies, 5 voices, and was last updated 15 years, 7 months ago by
Mr66MARTIN.
September 9, 2010 at 4:16 pm #57140
Mr66MARTIN
ParticipantOn spin, motor runs at its gradual increasing speeds fine but on final fastest speed it runs & runs. Have to move dial on manually to stop?
September 9, 2010 at 6:44 pm #329992shaun67
ParticipantRe: beko wm1512 motor run-on
I would meg the motor connector pins and check the tacho and check brushes on motor to rule them out first and wiring on connector block.I know the modules seem to act up on these from what i have found out but i would rule out the easiest first.
I have a wma1512w to look at tomorrow not taking powder from middle dispenser (main wash) but takes it ok from pre wash compartment already looked at it but could not find anything wrong ,no blockages and valves all working … :rolls:
September 9, 2010 at 9:15 pm #329993Jazzmeister
More than likely the module on this one!
Jazz
September 10, 2010 at 9:06 am #329994electrofix
ModeratorRe: beko wm1512 motor run-on
if you want tech info let me know full model numbers and an email address
September 12, 2010 at 5:35 pm #329995megawatt
Had an ISE5 mk1 doing the same thing (would not stop spinning). Found low insulation on motor, new motor sorted it.
Mike.September 15, 2010 at 7:47 am #329996Mr66MARTIN
electrofix wrote:if you want tech info let me know full model numbers and an email address
Beko WM1512S. 66martin@sky.com-ThanksSeptember 15, 2010 at 12:33 pm #329997electrofix
sorted
September 15, 2010 at 5:31 pm #329998Mr66MARTIN
electrofix wrote:sorted
Thanks for that Dave.Martin
September 16, 2010 at 4:04 pm #329999Mr66MARTIN
Motors fine,boards fine, I’am thinking its the timer. Don’t want to get new or recon timer if its something else-anyone had this problem?
September 17, 2010 at 9:29 pm #330000megawatt
Whats the earth insulation resistance of the motor?
Mike.September 20, 2010 at 11:24 am #330001Mr66MARTIN
megawatt wrote:Whats the earth insulation resistance of the motor?
Mike.All very high in fact to max my machine will test too >999mohms.
Also this machine has 3 spin settings-A & C work fine.Its actually B that continues to spin continuously.
Martin -
