beko wm1512s timer advancing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries beko wm1512s timer advancing
  • #73958
    johnnyj
    Can anybody help please got a Beko WM1512S with the timer just advancing on whatever programme it is set on, ive checked the brushes etc, but thinking it must be the timer HELP!!!
    #389445
    Seamy
    Re: beko wm1512s timer advancing
    Check NTC for short cable connection short circuit, if short it skips past wash thinking its full of hot water & sometimes goes to drain, also loom to fill valves can also get damaged by overloading & tub banging off it.
    Connection to hot water can have the same effect as NTC faulty as it detects hot water it will abort programme.
    #389446
    johnnyj
    Cheers seamy all sorted it was a duff timer JJ
