Beko WM1512W washer Ser. no. 02 – 102208 – 09
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WM1512W washer Ser. no. 02 – 102208 – 09
  • #17942
    aqualectric
    Beko washer WM1512W Ser no. 02 – 102208 – 09
    Select programme, switch on. Short pause, door locks, machine does not start and then timer slowly advances through to the stop mark. Tapped the relays on the PCB with a screwdriver and it started working OK. (only for a very short time). This board is listed as a ‘speed control’ only; so does it have the ability to fast-advance the timer if faulty? All ancillary parts working: pump, motor, fills, pressure bottle clear, wiring OK even PCB shows no signs of damage. PCB is expensive so need to be sure.
    Any help please!! 😕
    Steve.
    #177135
    Re: Beko WM1512W washer Ser. no. 02 – 102208 – 09
    Almost certainly module playing up – BE28047602190. Under £40 from SEME doesn’t seem too bad…………?
