Hi guys
Just been to the above machine, with no spin fault..
Brushes and tacho checked out fine,so ran the self test mode
On this the spin works fine! as does everything else!
Am i right in thinking that the self test does not use the voltage from the tacho, and therefore it will spin on self test?
Am goin back tommorow to try a new tacho, before replacing the board i guess.
The only thing i didnt check were the wires goin up to the board from the tacho connections on the motor connector
Any ideas welcome?
