Beko wm5100w fault
  • #88568
    Johnnydavie
    Hi has anyone came across this problem . My beko has started filling with water and spinning really fast for a few seconds then stops then takes more water and spins fast again . I put it on a test mode and as it went on spin it made a loud bang from underneath . I was going to get a circuit board but have been told it might be the tachometer on the motor .. Can anyone help
    #438603
    Re: Beko wm5100w fault
    could be tacho or the board either will cause this fault
    petehall347
    i would first check the wiring is intact on the motor . if so remove motor for bench testing . also look for burned boards etc .
