BEKO WM5100W fault codes?
  • #67478
    Set to a spin and the pump runs for a few seconds and then machine shuts down, same on all settings apparently.
    Checked all the obvious, motor, heater, NTC wiring harness, but no faults found.
    Used the same diagnostics routine as the ISE, turn to 90°, press S/P/C button whilst switching on.
    At first the Start/Wash/ Spin (or end ) lights were flashing.
    Advanced it on a few steps through the routine, the pump, valves & motor worked.
    At one step it would not advance further and the Start and Wash lights were flashing.
    Not sure of what this error code is, ignoring the Start light would give 100 or NTC fault.
    NTC and the wiring up to the PCB all appear to be OK.
    Am I barking up the wrong tree with that fault code?
    nigegt
    Re: BEKO WM5100W fault codes?
    I had one like this and it was the little program selector. nearly commited suicide trying to find the fault though then “Criscold” on here sent me some gumph but i’m cant find the email to forward to you with the codes. But he might be able to get you the info you need.
    Nige
    #367541
    He has been in touch already, I did have a read of your thread. 😉
    Is the selector a separate part, it looked to be part of the PCB to me, but then it was 7.25am this morning, eyes not fully working 😀
    #367542
    nigegt
    Hi yes it’s separate part but at first glance does look boardy lol (I ordered a board for that one in my straw clutching at stage!)
