Beko wm5100w not starting program
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko wm5100w not starting program
  • #100716
    Adam Fyfe
    Hi, I have this washer and it’s been great.
    now, when pressing the start button it begins to fill. Stops then fills again, then just stops. It never progresses.
    if I cancel the program holding the start button it drains and goes back to idle.
    any ideas ?
    thanks
    #481879
    tubafan
    Sounds like it’s waiting for the motor to start, which I assume doesn’t happen?
    #481880
    Adam Fyfe
    No, no motor noise nothing
    I’ve checked all cables are in their correct places.
    #481881
    have you checked the motor brushes ?
    andyjawa
    Yes it`ll surely be the motor brushes. Well worth repairing this machine and so well worth the effort to have a good look. These simple Beko entry level machines can be very long lasting and reliable.
    #481883
    Adam Fyfe
    It was indeed the brushes !!
    new ones installed and it’s working like a charm
    thank you. !
    #481884
    andyjawa
    Great. You are advised to run the brushes in by doing a couple of light loads first so that a “curve” on each brush running face angle beds in properly.
