beko wm5100w problem
  • #82421
    mike1
    hi,got a problem with the valve been sporadically energised
    at the end of the cycle,i have changed the pcb and tried a
    valve with no success,can anyone help thanks…mick
    #419799
    Re: beko wm5100w problem
    i am guessing a bit here but am i to understand the following
    tha machine goes through the programme and spins at the end only to fill up with water and wet the clothes again
    if so
    I had a beko that was connected to hot water doing that very thing.
    check for hot water inlet. if ok then look at poss ntc fault as i assume its the ntc thats sensing the overheat
    worth a try
    mike1
    no it doesn’t fill with water, it just makes a repetitive banging noise as the valve is sporadically energised.
    mick
    #419801
    codlets
    Had the exact same problem on a wma hotpoint today. Although as soon as the door unlocks it stops. Will let you know if i find a solution !
