BEKO WM5100W Washing Machine error
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BEKO WM5100W Washing Machine error
  • #68267
    Woldoc
    Machine went through complete cycle as normal and completed ok, removed laundry and refilled drum with another load. Pressed start, wash light illuminated. Nothing started, no sound, no clicks, no water input, no drum cycle. press start/pause and pause light flashes, press again and it goes off. Press Pause light for 3 seconds and spin/end light illuminates but then does nothing.
    Turned power off, held start/pause turned on, it enters test mode with ready light off, wash light flashing and spin/end light on solid. Cannot perform any other test, ie move selector to another program and press start does nothing. Turn off and on again returns the ready light as if its ready to start. At any point in the above the door is never locked and can be opened.
    I’ve emptied the filter/pump not a lot there, two coins. no water in the drum. Im going around in circles.
    However, an answer of what error code is indicating when in test mode would help (ready light off, wash light flashing and spin/end light on solid).
    Thanks in advance
    #370393
    Seamy
    Re: BEKO WM5100W Washing Machine error
    Last recorded fault code was Unbalanced load.
    Sounds like the door interlock has failed or pump has failed or that the impellor is jammed, when you press start the door should lock & pump should run before taking in water.
    Many people press start button too long or twice, which will either cancel programme or pause it.
    #370394
    Woldoc
    thanks for the reply and suggestions Seamy, i’ll take a closer look at these later today and let you know what i find.
