Beko WM5101 titsup – help please
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WM5101 titsup – help please
  • #70345
    MikeMaughan
    We bought our daughter a WM5101 just over a year ago as a 3-year stopgap (she was at teacher training college and neither she nor we had any spare money) and it has died.
    As far as I can ascertain a fridge on the same mains failed dramatically and caused a power surge to the washer. All wiring and supply-side fuses are ok, and I’ve traced good mains to the on side of the on/off switch where it goes down to a white plastic/metal unit like a wagon wheel biscuit mounted halfway down from the top to the right of the front panel.
    Without dismantling more I cannot either unmount this unit or see anything more about it, but as none of the panel idiot lights work – and the machine is unresponsive – I surmise this unit is a good candidate for the problem.
    Can anyone help with this, please?
    Firstly I don’t know what this thing is or what it does. Both mains go in and two connectors leave. There is power going in & nothing coming out. I can find no reset button or any other clue so I’m guessing it’s a fuse or failsafe of some sort?
    Is there anywhere I can look at a circuit diagram, service manual, parts explosion or the like?
    Sorry it’s a lot to chew on before the F1 but we doo need some informed help here.
    Regards, Mike
    #377850
    Seamy
    Re: Beko WM5101 titsup – help please
    Not sure but the wagon wheel type biscuit thing you describe could be a pressure switch.
    Power on most Bekos will come in on the maims cable through a filter/suppressor onto mains switch.
    Most likely from what you describe so eloquently , the P.C.Bs away, not an expensive part though compared to most makes. Part num’ 2324100400
    #377851
    MikeMaughan
    Thanks for the comments, Seamy.
    As the unit is only just out of warranty we’ve managed to persuade Beko to fix it FOC, a nice gesture from them.
    Regards, Mike
