Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › BEKO WM5102W Auto Washing Machine lights on but not working!
- This topic has 7 replies, 4 voices, and was last updated 12 years, 5 months ago by
Danny_Swede.
October 13, 2013 at 11:44 am #77597
Danny_Swede
ParticipantPlease Help!!
My washing machine is new and ive only used it 3 or 4 times. But now when i tried to wash today, i put it on the normal cycle and hit start. The ready/wash light comes on, but nothing happens… ive tried other cycles and i get the same.
Does anybody know what i need to do?Thanks
Danny
October 13, 2013 at 12:48 pm #402745Andy jones
ParticipantRe: BEKO WM5102W Auto Washing Machine lights on but not work
Make sure the door is firmly shut and try again
Sent from my iPad using Tapatalk HDOctober 13, 2013 at 3:54 pm #402746Danny_Swede
It is shut, like i said its only a month old. i switch it on and the light flashes on the End/Cancel, so i press start, and the wash light comes on but nothing happens.
October 14, 2013 at 8:04 am #402747spanishwhite
Is it fitted with a time delay facility?If so check this has not been activated accidentally.
October 14, 2013 at 9:37 am #402748Danny_Swede
It does have one, and i did check this but this isn’t on.
I’m completely baffled!
October 14, 2013 at 1:51 pm #402749spanishwhite
Ok,back to basics.If the door is closing correctly, the time delay is not activated or any child lock switched on.Check the water supply is on and that there is no kinking in the inlet pipe.If all these are correct contact the supplier as it is a new machine and will be covered by a warranty.
October 14, 2013 at 3:54 pm #402750Seamy
Try reading the user manual.
Many many many people, hold in the start button to start it, it just needs to be pressed once!
If you press it too long it either pauses the programme or cancels it altogether.
Under the start button it says “Cancel hold in for 3 sec’s”, some misread this as to start you must hold in, where as you just press button once to start.October 14, 2013 at 7:46 pm #402751Danny_Swede
hi,
nope, none of the above. thanks fo the suggestions though… i also seem to have misplaced the receipt!
