Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Beko wm5120s
- This topic has 11 replies, 5 voices, and was last updated 14 years, 10 months ago by
elfy1960.
June 3, 2011 at 9:58 pm #63168
elfy1960
ParticipantHi my washer is playing up when you turn it on the ready light should come on but instead the wash light comes on,it will then either fill up and do nothing else or it wont fill up at all, if you pause it and select drain to empty sometimes it will and other times not.I have had the motor out and checked the brushes and they are fine whenput the motor back on and tried it it worked ok but today its acting up again, any pointers to what i should do please . Elfy
June 3, 2011 at 11:41 pm #352827kwatt
KeymasterRe: Beko wm5120s
It may be a board fault depending on the number of LEDs that machine has on it. Does the light flash or is it constant?
June 4, 2011 at 9:32 pm #352828elfy1960
ParticipantRe: Beko wm5120s
The wash light is constant and when pressed it flashes in pause mode but the ready light should be on. Tried it again today and it filled up then thats it nothing else happens,flicked it over to empty and still nothing .
June 4, 2011 at 11:11 pm #352829kwatt
I think, from what I can see, that the machine is telling you that the heater is open circuit, easily tested with a meter.
June 5, 2011 at 12:04 am #352830elfy1960
Cheers for that info but now what do i do , i have a multi meter . does it mean a new heater or is it faulty wiring
June 5, 2011 at 10:07 am #352831kwatt
You need to test it as I said.
June 9, 2011 at 8:27 pm #352832elfy1960
Hi ive tested the heater for continuity and my meter bleeped so thats saying the heater is ok but am still not getting it to work. All it does now when you switch it on is run the pump for a few seconds then zilch . Is there any other test i can do on the heater as i have seen another post about a beko and they too were told to check the heater, cheers Elfy
June 9, 2011 at 8:52 pm #352833johnsdad
Check the motor brushes, it won’t start a prog if they are worn out
June 9, 2011 at 9:28 pm #352834elfy1960
Have already checked the brushes they are fine
June 10, 2011 at 7:47 am #352835washtronics
hold start button in until end light comes on, wait for door to unlock then you can start programme again
June 10, 2011 at 6:52 pm #352836elfy1960
The end light is already on when the washer is turned on. Is there any other test i can do on the heater, don,t want to buy a new one and find out its something else
June 24, 2011 at 6:56 am #352837BEKOBOY
Check the drain pump impellor, as if it gets obstructed, it will give the electronics o the unit to play up and lock programmes. Quyite a common fault with this model.
