Beko wm5120s motor or mod?
  • #63453
    jimluxe
    hello
    not sure if its board or motor. set prog to spin press start and motor tries to go full speed then cuts out if you set wash prog then machine fills to normal but same again. no flashing lights just ready to start prog again.
    tacho is ok and readings from motor seem ok
    anybody point me in the right direction please.
    #353834
    Re: Beko wm5120s motor or mod?
    It’s probably a tacho fault?
    Have you tried ‘Advance Search’ on the subject?
    Tech questions should be posted in Trade Technical not General Trade by the way! 😉
    #353835
    lee8
    It could be both it could be one, depends on which one tests faulty, if motor tacho has been tested properly and is ok, its the PCB, if not its the motor.
    Beko advice to there agents is to change both,as there has been an issue with both causing loss of motor speed control, but there biased to you using parts whether you need them or not.
    Its unlikely to be both, but you never no, everything on a W/M can become faulty, there is no such thing as a standard fault with a symptom, some confidence and knowledge is the key to a successful repair.
    #353836
    allan73
    I think there are some threads on here about tacho magnets cracking on Beko’s.
    Allan.
    #353837
    jimluxe
    Thanks Allan and Martin
    yep it was a cracked tacho magnet, got a reading from it and thought
    it was ok. next time i will remove the cover and look with my eyes and not just rely on my meter ( should know better after 30 years)
    sorry for posting in the wrong section Martin but not used to this new layout yet.
    #353838
    Moved you on Sunday. 😉
