Beko wm5120w module?
  • #48019
    allan
    Hi all just to been to a Beko wm5120w, set program ready light comes on, door is locked, press start, ready light goes off machine does nothing on any program
    cant find anything else wrong tried the cancel, does nothing, suspect the module, anything else i should check?
    Thanks Allan
    #295307
    djohnston
    Re: Beko wm5120w module?
    check white wire going into pressure switch could have came loose , if not difinately pcb part no:- 2822970282
    #295308
    allan
    Thanks will check that before ordering, and thanks for the part no. 🙂
