Beko Wm5120w stopped running
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko Wm5120w stopped running
  • #97666
    GhostAT
    Hiya,
    ​​​​I got an issue with my waching machine, worked completely fine and suddenly stopped during the washing programe. Cleaned the pump filter and drawer but didn’t help. Found on other forum how to run the error code checks but don’t have the full listnof errors. On mine start /pause light is flickering and both ready and spin/end lights are on.
    Any help will be much appreciated.
    #468939
    coming up with al ist of faults is easy. trying to figure how to apply them is something different. I think its to do with the programme flow light but since i cant see yours i cant guess
    GhostAT
    Thanks Dave for getting back to me.
    ​​​​​​Not really sure how to read that I am afraid.
    More than happy to do whatever needed to make that work so will appreciate all the ways/tips how to make that happen.
    ​​Cheers
    Arek
    #468941
    there is a row of light that show the progress of the programme. I think they use these lights
    there will be one ofr wash, i assume one for rinse and one for spin
    am guessing first fault code 100 is wash light on rinse and spin off
    if that sort of fits what do you have ?
    GhostAT
    Got it now.
    It’s 101 in this case + start/pause is flickering on the top of that
    #468943
    well thats a start, try checking the pump and the wires feeding it
    you need to check the pump coil continuity
    when you set a programme how long before you get the fault ?
    dave
    #468944
    GhostAT
    Filling up with water to the bottom of the drum and stops in about 2 mins from the start of the programme.
    Took it out, checked both water pipes and power wire and looks all fine, I know it’s very basic but I am not an engineer. Happy to check the pump wires if you direct me where to look?
    #468945
    does the drum turn ?
    have you checked the motor brushes ?
    GhostAT
    Changed the brushes and seem to be working fine for now. Thanks for all the help!
