Beko WM5120W Washing machine-Spin cuts in
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WM5120W Washing machine-Spin cuts in
  • #82915
    Latham63
    When on spin prog machine will do nothing then intermittently the spin + pump will cut in fast,then off.
    Motor checks ok.
    Suspect pcb as this is controlling the motor/pump?
    #421101
    Re: Beko WM5120W Washing machine-Spin cuts in
    does it work normally on the wash programme
    ie motor turns slowly
    Latham63
    Checked tacho/wiring & tried a spare motor.No change.
    New pcb fitted…all is well.
