BEKO WM5140W Spinning to fast.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum BEKO WM5140W Spinning to fast.
  • #71419
    CiderVisor
    Hello,
    Model – Beko WM5140W
    Last week our Beko stopped spinning completely. I suspected the brushes, took it apart and replaced them. It has been running fine the last week.
    However at the weekend it started spinning up and then stopping. The program continues along it seems but every now again we get this erratic spin up. Spin program behaves the same. The pump seems to be running fine.
    Here’s a video of the behaviour:
    http://youtu.be/8UQaHpVa_Vw
    I took the back off tonight and checked all the connections. Also took the PCB out and looked for faulty/blown components.
    Any ideas?
    Thanks in advance.
    Pete
    #380986
    captaincaveman1
    Re: BEKO WM5140W Spinning to fast.
    Could be the tacho on the end of the motor is either loose or open circuit however I have known the main pcb also cause this fault on this range so check the motor first if thats ok then it has to be the pcb
