BEKO WM520S
  • #48674
    robbo1973
    hi been here today and the machine door will lock the valves “clunk” like the servis machines do then the start button starts to flash continously no pattern of flashes.i have checked the heater motor ,carbons and valves.
    any beko experts out there
    cheers chris
    #297350
    robbo1973
    Re: BEKO WM520S
    are these prone to pcb faults?
    cheers chris
    #297351
    A1engineer
    Re: BEKO WM520S
    probably will be the pcb changed a load of them for various faults are fairly common imo easy enough to change tho and not that expensive 😉
    #297352
    Galway
    Re: BEKO WM520S
    have had similar call outs and probably the pcb but on more than one occasion it has been stuck in the previous cycle and just needed to be cancelled by keeping the start button pressed even though the customers have said they tried this already.
    hope this helps.
