I have been out to a WM6152w where it will fills to level … no motor action no pump action will not respond to cancel button i have change the PCB still the same Any Ideas Please
Allsorts wrote:Check the motor, tacho, and brushes.
As allsorts said above ..i had a similar problem and motor was the problem with brushes and tacho..Fixed tacho and new brushes and all is fine again.same happened to another beko i looked at which was a different model but had same fault as mentioned.
Great Fellas nice to have some back up as i have returned to field work again after a few years off (am i mad)i hope to get to the meeting in coventry on Friday Might see some of you there
