Beko WM6167 carbon brush problem.
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WM6167 carbon brush problem.
  • #71693
    gbar
    I have a 13 month old Beko WM6167 that is now on it’s third set of brushes. Each time on replacing the brushes, one brush is completely worn and the other is about 15mm to 20mm in length. After fitting the latest set, I ran the machine on a spin cycle and watched the motor as it gained speed. On the lowest and itermediate speeds everything appears fine but, as soon as the motor switches to the highest speed, the brushes start arcing and crackling. Can anyone suggest what the cause is likely to be?
    #381973
    Re: Beko WM6167 carbon brush problem.
    You need a new motor, the armature is goosed.
    #381974
    gbar
    Thanks for the reply. I feared it would be the motor. I’ll see if I can get any joy from Beko on a free replacement – although not very confident that they’ll help!
    Thank you.
