Beko WM6167W
00 02 in display and not starting, the only thing working is the delay timer which increases the the time but 02 will not go when I come back down and try and get zero
Changed carbon brushes which had warn right down.
Not sure if 00 02 was a fault code and I need to exit it but how or damaged PCB
Any ideas
I think it shows the time remaining? (ie 2 mins) which would be an out of balance spin problem. If that is so then simply press and hold the Start/Pause/Cancel button. Time delay by the way can only be set in 30 min intervals.
Ring Beko Tech.. According to ‘Your Money Their Tricks’ last evening on BBC1, Beko are the only Manufacturers offering tech advice to independents… It’s got to be true, it was on the BBC 😀
