beko wm6167w
  • #70508
    mowerman80
    Hi i have this washing machine which filles and rotates once then just stops and does nothing i presume its the control board at fault . tested heater etc and fine the serial number is 7160881200 but have two different part numbers for the board,5045176328546 and 5045178529194 does anyone know which one it is or any other info would be good .thanks.
    #378246
    Criscold
    Re: beko wm6167w
    Pm your email and can send you some info
    Colin
    #378247
    mowerman80
    Re: beko wm6167w
    Thanks for all the info colin ,will go back and have another look.paul.
    #378248
    mowerman80
    Re: beko wm6167w
    Ok been back and its a e11 fault code (no anti clockwise motor action) so its the motor relay on the control board. Can anyone tell me which part number it is for the board and what are the differences between the two part numbers? as there is a price diference . Thanks.
    #378249
    Criscold
    Re: beko wm6167w
    The part listed for this model is 2822822301 Connect No.5045178529194
