Beko WM6355W spin problem
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WM6355W spin problem
  • #92358
    OlliePlimsolls
    Hi all, bit of a strange one:
    This machine spins, but not as it should. The motor works in momentary ‘pulses’ at intervals of roughly a second or so. This is accompanied by a little squeak as the belt slips slightly.
    I’ve entered the test mode and it’s given an error code of ‘F06’ which I can’t for the life of me find the description for.
    If I cycle through the test mode, it will spin up nicely to the full 1500rpm high speed spin speed and sit there happily. But on the low speed (whatever it is during the actual wash cycle) spin test it does the strange pulsing behaviour.
    Any ideas?
    Thanks in advance.
    #451060
    Re: Beko WM6355W spin problem
    can you check the model I cant find it
    OlliePlimsolls
    Hi, it’s definitely WM6355W.
    It’s an older model, from around 2010-ish.
    Bit grubby now from having had my fixing mitts all over it!
    If it helps, it’s identical in appearance to the WM5100 model, but with the addition of a digital display/timer on the panel.
    #451062
    just seen your reply don’t know why I could not see it and not got time to check now
    but from fault description sounds like a tacho magnet fault
