Beko WM7120W door seal failure
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Beko WM7120W door seal failure
  • #95426
    Martinh89
    Hi All,
    We have a Beko WM7120W washing machine that’s now about 7 years old. The other day I pulled a lump of rubber out with a load of washing which I subsequently identified as being the inner part of the door seal, where the seal would normally rest nearly against the drum, down to the drum clamp section. Assuming that the machine had had a good life and rubber wears out, I purchased a replacement seal and fitted it. I then ran a rinse cycle to check for leaks and put a round of washing in on a cottons cycle at 40. Having got the washing out it is evident that the new seal has failed in the same place around significant portions of its circumference. It appears as if the action of the drum is ripping the seal to pieces. Is this likely to be a fixable problem, or time to go shopping for a new machine?
    #460318
    has the machine been making a lot of noise?
    it does sound like the inner drum has gone. In fact I think its one of the arms of the drum spider that has failed. causing the drum to go out of line on spin catching the rubber
    think its beyond repair
