Beko WM7147W wont wash Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Beko WM7147W wont wash This topic has 3 replies, 2 voices, and was last updated 13 years, 2 months ago by J Rooney. Viewing 4 posts - 1 through 4 (of 4 total) Author Posts February 7, 2013 at 7:49 pm #74030 J RooneyParticipant The washing machie will only turn in one direction then seems to freeze and wont move again. Any help appreciated. February 7, 2013 at 8:20 pm #389671 leedata1979Participant Re: Beko WM7147W wont wash Hi there Your Machine is controlled by the PCB which is a compute that tell the motor which way to turn. you will need to replace this and that will sort the problem out. but shop around for the right model as they are not cheap to replace. February 7, 2013 at 8:31 pm #389672 J RooneyParticipant Re: Beko WM7147W wont wash Thanks leedata1979 Do you know which PCB it is, as there appears to be several and can it be repaired (soldered) or is it a defo replacement? Cheers February 10, 2013 at 10:53 pm #389673 leedata1979Participant Re: Beko WM7147W wont wash You could try and have a look and see if it can be soldered but i dont think so as it is more then likely to be a component on the board. Author Posts Viewing 4 posts - 1 through 4 (of 4 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
