Beko WM74135 no motor action
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Beko WM74135 no motor action
  • #93931
    delta01
    hi just fitted carbons to this machine it did not cure the nma i suspect module.
    the machine starts to pump out on spin then stops with12 minutes on display it does not count down any help appreciated thanks John
    #455936
    suedehead1
    Re: Beko WM74135 no motor action
    possibly blew dc module
    #455937
    delta01
    thanks is that the one on the side is it repairable
    #455938
    wilf
    Usually blows the track off. I found that if it’s blown it’s a sure sign that the motor is u/s Look for any tell tale signs on the com or brush holders. I wont fit a new pcb and risk blowing it as it’s quite a hit. A Beko engineer told me that they never change one without a new motor, but out of guarantee that’s BER.
    regards wilf
    #455939
    delta01
    thanks for input wilf i repaired tracks on module motor it now goes up to full speed then stops i ordered a s/h module so will try that i think it blew because one brush was right down i cant see any obvious motor problems
    #455940
    check the tacho magnet on the back of the motor
    if they break the motor accelerates but with no feedback the module shuts it down
