Hi, I’ve been given this machine to diagnose : Beko WM74155LW. The machine fills and empties, but the motor won’t run
Looking at the board, after the pump stops I would expect the relays to operate to drive the motor, but I hear no click. I’ve measured the voltage across each relay with a multimeter. When the pump runs, I can see 12V across the coil, but nothing at all on the other relays.
Hi, I have a problem with this model too. The motor turns but is interrupted immediately on any programme. It fills and empties fine but the programmes abort and something is telling the motor to stop as soon as it starts. I have cleaned out the filter and changed the brushes on the motor but no change. Can’t see anything obvious.
